i have a 04' (305hp) cummins, and i noticed that the 03's have a different # for the puck then the 04'.. why is that? mainly asking, i thought about tryin my buddies puck off his 03 on my truck?
Also, is it fine to run the predator on regular tunes, and still turn up the puck if i wanted? i didnt know if it matterd if it wasnt on the stack settings.
thanks
04' Cummins power puck???
RE: 04
There are year to year differences in the way the pucks wire into the harness.
For best performance and safe EGTs you should use the provided Stack tunes when running the PowerPuck.
CTDpowerTN
The stackable tunes will produce a little less power than the non stackable tunes, they are completely safe to run with or without the puck.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
CTDpowerTN
You will get a check engine light related to fuel pressure if you run the non stack tunes with the puck. I forgot the exact P-code it gave.
Diablosport INC
Diablosport INC
Yes.bcmopar wrote:Can you run just the puck with stock tune
