Cannot load the Tow tune LMM
bitecho
Post by bitecho »
All of my other HP tunes work but the tow tune. It falls back on the failsafe and the original backup has to be reloaded. Says that the "Trailer Brake System Needs Service" on the cluster.
I have recieved one update on this programmer, when I purchased it.
2007 K2500HD LMM
U7186
sn# 266945
v.9t13g is the current revison
How do I correct this?
ECM_628594628778.grd
Original File from ECM
(117.2 KiB) Downloaded 205 times
2007.5 K2500 HD Z71 LMM
Stock
Daily Driver
U7186
RE: Cannot load the Tow tune LMM
Please restore the stock tune and update to the latest 9r15 and try again.
bitecho
Post by bitecho »
Relaoded the stock tune and updated the predator to the 9r15 crom. After saving the stock tune to the programmer, it shows all of the loaded tunes. The tow tune will not load, it goes half way through the write then shows the fail safe screen. then you have to reload the stock program. I did not attempt to load any of the other tunes to see if they would work. I am only interested in the tow tune at this time. I made three attempts to load the tune. Can you fix this issue? I had the same problem when it was new out of the box......
Stock
Daily Driver
U7186
Odd, never seen this before.
Can you please post your VIN and the list of calids from options/troubleshooting/show calid?
bitecho
Post by bitecho »
I pulled the requested information from the ECM. When I purchased the tuner back in January the 9r12 crom would not work on this truck at all. You sent me a custom crom once before on this same truck. The tow tune wouldn't work with that firmware either.
VIN# 1GCHK24607E544342
Calids#
12628596 Boot Software
12628594 Main OS
12628796 Speedometer
12643813 System
12628785 Fuel System
12628779 Engine Diagnostic
12634941 Engine Operation
12628798 Engine
12628595 Slave OS
I compaired it to the calibration history for this truck on GM Service web site. All are up to date.
http://tis2web.service.gm.com/tis2web/? ... CDBKCDJBCD
I tried once again to see if I could get it to work. Again it falls back on the failsafe and forces the stock program to be reloaded on the ECM. The dash dispalys "Service Trailer Brake System" and "Service 4 Wheel Drive". Reaload the program and the turck operates like normal. Checked the truck with a MAC Scanner to verify that everything returned back to normal.
You can enter the VIN on this site to get any other info you need on the truck.
Stock
Daily Driver
U7186
Interesting, we're looking into it.
bitecho
Post by bitecho »
Any luck on finding the issue with the tune?
Stock
Daily Driver
U7186
No, have not been able to reproduce it yet, but they are still looking into it.
bitecho
Post by bitecho »
I got the tune to work. I found two dead cells on the left battery. The voltage at the OBD connector was 12.5v when the key was off. When the key was switched to the on position the battery voltage would drop to 11.1 volts after about 3 minutes. I am sure that this was the issue with the programmer. The truck has been sitting in the garage for the past six months, only being driven when needed. I guess I haven't noticed any starting issues because I have a Battery Tender plugged into the truck while it sits and it is summer. I replaced both batteries and tried the programmer, it works..... The truck still had the factory installed batteries.....
Stock
Daily Driver
U7186
