2008 FORD F350 - Speed limiter
The speed limiter seems to have to effect on this truck. I have tried to adjust it at several speed limits with no luck. This is a work vehicle and the tuner was purchased to set the speed.
RE: 2008 FORD F350 - Speed limiter
what revision are you using?
Sorry. I have the latest revision 9r12a
try 9t13g please:
https://www.diablosport.com/index.php?n ... ad&id=5236
I will try it A.S.A.P. I will let you know what happens.
Installed the new revision still does not hold speed limit. Trying to set speed limit for 74mph Vehicle still exceeds 100mph. Is there a specific tune to set the speed on? I.E Tow tune, Performace tune etc...???
It should work in any tunes, let me look into this.
can you post your calibrations?
I will try to post them soon as. The changes I made were the speed limit to 74 and transmission shift points down to 3100 no other changes.
Unable to get tune file from predator. Downloader "unable to export tune tow tune modified".
just need the calids, not the files themselves, sorry
Cal ID's 8U7A-14C204-CF
7U7A-14C337-AB
7U7A-14C337-AB
thanks, we'll get this fixed in the next rev.
Cool thanks. Any ETA on that?
Any luck yet with the speed limit fix? Have four units I need to set the speed limit on.
