2008 FORD F350 - Speed limiter
Callbeck1
Post by Callbeck1 »
The speed limiter seems to have to effect on this truck. I have tried to adjust it at several speed limits with no luck. This is a work vehicle and the tuner was purchased to set the speed.
RE: 2008 FORD F350 - Speed limiter
what revision are you using?
Callbeck1
Post by Callbeck1 »
Sorry. I have the latest revision 9r12a
Callbeck1
Post by Callbeck1 »
I will try it A.S.A.P. I will let you know what happens.
Callbeck1
Post by Callbeck1 »
Installed the new revision still does not hold speed limit. Trying to set speed limit for 74mph Vehicle still exceeds 100mph. Is there a specific tune to set the speed on? I.E Tow tune, Performace tune etc...???
It should work in any tunes, let me look into this.
can you post your calibrations?
Callbeck1
Post by Callbeck1 »
I will try to post them soon as. The changes I made were the speed limit to 74 and transmission shift points down to 3100 no other changes.
Callbeck1
Post by Callbeck1 »
Unable to get tune file from predator. Downloader "unable to export tune tow tune modified".
just need the calids, not the files themselves, sorry ;)
Callbeck1
Post by Callbeck1 »
Cal ID's 8U7A-14C204-CF
7U7A-14C337-AB
thanks, we'll get this fixed in the next rev.
Callbeck1
Post by Callbeck1 »
Cool thanks. Any ETA on that?
Callbeck1
Post by Callbeck1 »
Any luck yet with the speed limit fix? Have four units I need to set the speed limit on.
