2011 Mustang GT AUTO trans
Dears Support,
I am facing two problems after I load the preloaded 91- 93 JLT tune
- When I load the JLT 91 or 93 tune file to my car I noticed that there's a DIG sound when transmission down shifting at low speed from 3rd to 2nd and from 2nd to 1st
- When racing the transmission is hanging at 4th to 5th for a while then shift
RE: 2011 Mustang GT AUTO trans
What version is on your Trinity?
Mine is better,still won't shift 4-5 at WOT.Other than that it's the best tune so far.Awsome ,just wish I didn't have to lift to make the one shift.I know you guys are working on it. It shifted fine with the dynotune. Must be something in the CAI file.
Tomorrow i will install the new ford update a just the dynotune and try and see how it shifts.I will make sure my A/F ratio is ok and give it a try (before I try the CAI tune) you sent me last. What ya think? Any tips? Thanks Bud (I'll let you know how it goes)
SOunds like a plan, lemme know.
Got the dynotune I left Florida with back in the car just long enough to get it warmed up. High to mid 12s A/F ratio at WOT.I will find a place to see how it shifts.Then I will just richen it up a bit if it works like it did when I had this tune without the CAI.I had seen 170 + mph with no shift probs at all.The last 212-2 was the best running and streetable tune ever(had to lift to shift 4-5),with the Steeda CAI.I'll let you know. Here is the dynotune if it will help.
- Dynotune.frg
- original I changed the name to dynotune to recognize it easy
- (1015.97 KiB) Downloaded 341 times
- PCM_FSDL5A8.frg
- I think this a copy that always suggest pairing with for the 212 tunes you have sent me
- (1015.99 KiB) Downloaded 412 times
Dear Mikel,
I updated my tuner to last version (v.1r08g) and I still facing the same problems
Not shifting from 4th to 5th at WOT
Knocking when downshifting from 2nd to 1st
I also have 4.10 gears installed on my car
is your speedometer correct?
I think so , I have 4.10 gear and 275/40/19 rear tires
I set my axle ratio to 4.10, 729 rev per mile and enabled the tire change option
can you post up the last tune written from your tool?
last tune written
Here is the last tune written to ECU and the stock tune
- PCM_FSDL5G2.frg
- Stock tune
- (1017.21 KiB) Downloaded 369 times
- PCM_FSDL5G2_JLT_CAI_93_Octane_modified.frg
- Last tune written
- (15.25 KiB) Downloaded 331 times
RE: last tune written
I have had the same problems.Try running with the shift button pushed in.It makes the light on the dash come on. If that doesn't work , run with it off until you get ready to make the 4-5 shift then push it and it should shift as soon as you push it I know this is not a fix for this problem,but it works for me. I hope they get this issue resolved soon. I hope the shift points will be changeable soon also.Mine also clunks when downshifting from2-1.I have stock gears & tires on mine.
Re: RE: last tune written
Hey budlun,budlun wrote:I have had the same problems.Try running with the shift button pushed in.It makes the light on the dash come on. If that doesn't work , run with it off until you get ready to make the 4-5 shift then push it and it should shift as soon as you push it I know this is not a fix for this problem,but it works for me. I hope they get this issue resolved soon. I hope the shift points will be changeable soon also.Mine also clunks when downshifting from2-1.I have stock gears & tires on mine.
Man that clunks when downshifting from 2nd-1st. is about to kill me
do you mean the over/drive button ?
what revision are you running?b-abed wrote:Hey budlun,budlun wrote:I have had the same problems.Try running with the shift button pushed in.It makes the light on the dash come on. If that doesn't work , run with it off until you get ready to make the 4-5 shift then push it and it should shift as soon as you push it I know this is not a fix for this problem,but it works for me. I hope they get this issue resolved soon. I hope the shift points will be changeable soon also.Mine also clunks when downshifting from2-1.I have stock gears & tires on mine.
RE: Re: RE: last tune written
For those with a 4-5 shift issue. Please check the build date of your car. There is a new TSB out for flaring 4-5 shifts for cars built before 12/10/10 . The fix is 3 new solenoids in the transmission. The button truck probably works because it commands the shift sooner.
I will check into the 2-1 clunk.
