So I get under the hood and I believe I found the fuel sensor where I need to install the power puck to. The problem is, it's in this bracket and I cannot get my hands in to to release the harness. Do I need to remove the bracket or is there a trick to getting this? The instructions don't mention the bracket at all, so I want to be sure.
Lastly, cars and trucks used to have several places in the firewalls to run extra wires etc. I checked and it appears there are none on this truck. Has anyone found that it's required to drill?
2011 6.6 Harness install
frankl
RE: 2011 6.6 Harness install
no trick to it that I know of, you should be able to just unsnap the plug. Here is a link to the instructions.
http://diablosport.com/beta/forumfiles/ ... ax_206.pdf
