calid
RE: calid
sounds like you now have a newer calibration ID in the ecm than what is supported by the trinity...
it may not let you install a tune, but it should let you save a copy of the original backup stock tune file... is it not letting you even do that??
RE: calid
hi thanks for the quick reply. no it still says the trinity is not married. if i try to proceed my truck goes to a no start with engine light on then 5 min later it will start. but the funny thing is i can pull up off the trinty the new files that gm installed
RE: calid
if you clear the codes, it will start.
let it save the stock tune, then export it using DSDL and post it here please, we'll get it added.
RE: calid
ok i have the original backup on it how do i post it? thankyou
ok figered it out here you go
- PCM_617631651467.grg
- (57.19 KiB) Downloaded 147 times
RE: calid
will be in the next update...
Re: RE: calid
here you go.Blueox wrote:Thank you im just excited to get this thing working
- trinity_gm_can_gas-1t08gr_update.crom
- (1.37 MiB) Downloaded 131 times
