2011 GMC Denali 1500 6.2L Transmission adjustments
selmahotrod
I just updated my Trinity 1000 and I see no adjustments for the transmission like the new up dates stated- what am I doing wrong?
2011 GMC Denali 1500 2wd 6.2L
Re: 2011 GMC Denali 1500 6.2L Transmission adjustments
update to thisselmahotrod wrote:I just updated my Trinity 1000 and I see no adjustments for the transmission like the new up dates stated- what am I doing wrong?
- trinity_gm_can_gas-1t08gq_update.crom
- (1.37 MiB) Downloaded 362 times
tmichelena
it will ask you to select the pcm tune then the TCM tune.
tmichelena
tmichelena
Hi again, Mike,
I just updated to the latest file dated 11-17 from the site. I completed a stock backup and then tried again. It extracts all the stock data and reads TCM. I then select Diablo Tune, and it uploads. It doesn't ask me to select a TCM tune.
Tom
Tom
- TCM.JPG (28.49 KiB) Viewed 6484 times
- TCM2.JPG (24.78 KiB) Viewed 6484 times
sounds like the tcm file is not supported, you should see a message to that effect somewhere.
Please export a copy of the TCM backup and post it here or email it to me and we'll add it asap.
tmichelena
I'm having the same issue, not able to install TCM tune, only PCM.
2011 Silverado 6.2L 2wd.
I've attached my stock tune backup file and the installed diablo tune. Any help appreciated.
Jerod
Jerod
- PCM_639835627564 Original stock tune.grg
- (5.25 KiB) Downloaded 255 times
- PCM_639835627564_Diablo_Tune 1.grg
- (5.25 KiB) Downloaded 251 times
Please export a copy of the TCM backup.BigJ wrote:I'm having the same issue, not able to install TCM tune, only PCM.
Jerod
you are added here.tmichelena wrote:Hi Mike,
Awesome, thanks!!
Tom
- trinity_gm_can_gas-1t08ha_update.crom
- (1.37 MiB) Downloaded 276 times
tmichelena
tmichelena
Mike,
Here's what happened. Everything worked great on the upload. Tonight, we were trying to upload the DiabLew tune and received the following messages. These errors occured with the exact same tool and cable that have been working flawlessly all along. We tried multiple times unplugging and replugging the tool in, starting truck, opening door, closing door, driving, ect. So, I'm thinking we got an error somewhere. Any suggestions?
Thanks!
Tom
Thanks!
Tom
- 1.jpg (34.68 KiB) Viewed 6248 times
- 2.jpg (33.12 KiB) Viewed 6248 times
restore the vehicle back to stock...
install canned/preset diablo tune for ecm...
then import my custom tune custom tune to the trinity...
install my custom tune to the ecm...
THEN install diablo tcm/tranny tune...
see how it works in that order...
tmichelena
