2011 GMC Denali 1500 6.2L Transmission adjustments
General Trinity Support
selmahotrod
Post by selmahotrod »
I just updated my Trinity 1000 and I see no adjustments for the transmission like the new up dates stated- what am I doing wrong?
2011 GMC Denali 1500 2wd 6.2L
Re: 2011 GMC Denali 1500 6.2L Transmission adjustments
selmahotrod wrote:I just updated my Trinity 1000 and I see no adjustments for the transmission like the new up dates stated- what am I doing wrong?
update to this ;)
trinity_gm_can_gas-1t08gq_update.crom
(1.37 MiB) Downloaded 362 times
tmichelena
Post by tmichelena »
Hello,
I've updated to this but don't see a transmission section. How do you modify the transmission?
Thanks!
Tom
it will ask you to select the pcm tune then the TCM tune.
tmichelena
Hi Mike,
It doens't ask us that. 2011 Chevy 1/2 ton 4X4 6.2L. It only asks me to select the engine tune, I select Diablo Tune. Then, it installs. No TCM questions...
Thanks,
Tom
tmichelena
Hi again, Mike,
I just updated to the latest file dated 11-17 from the site. I completed a stock backup and then tried again. It extracts all the stock data and reads TCM. I then select Diablo Tune, and it uploads. It doesn't ask me to select a TCM tune.
Thanks,
Tom
sounds like the tcm file is not supported, you should see a message to that effect somewhere.
Please export a copy of the TCM backup and post it here or email it to me and we'll add it asap.
tmichelena
Hi Mike,
Awesome, thanks!!
Tom
TCM_256125258808.grg
(54.25 KiB) Downloaded 253 times
BigJ
Post by BigJ »
I'm having the same issue, not able to install TCM tune, only PCM.
2011 Silverado 6.2L 2wd.
I've attached my stock tune backup file and the installed diablo tune. Any help appreciated.
Thanks,
Jerod
PCM_639835627564 Original stock tune.grg
(5.25 KiB) Downloaded 255 times
PCM_639835627564_Diablo_Tune 1.grg
(5.25 KiB) Downloaded 251 times
BigJ wrote:I'm having the same issue, not able to install TCM tune, only PCM.
Thanks,
Jerod
Please export a copy of the TCM backup.
tmichelena wrote:Hi Mike,
Awesome, thanks!!
Tom
you are added here.
trinity_gm_can_gas-1t08ha_update.crom
(1.37 MiB) Downloaded 276 times
tmichelena
Thank you very much! I will try it today.
Tom
tmichelena
Mike,
Here's what happened. Everything worked great on the upload. Tonight, we were trying to upload the DiabLew tune and received the following messages. These errors occured with the exact same tool and cable that have been working flawlessly all along. We tried multiple times unplugging and replugging the tool in, starting truck, opening door, closing door, driving, ect. So, I'm thinking we got an error somewhere. Any suggestions?
Thanks!
Tom
restore the vehicle back to stock...
install canned/preset diablo tune for ecm...
then import my custom tune custom tune to the trinity...
install my custom tune to the ecm...
THEN install diablo tcm/tranny tune...
see how it works in that order... ;)
tmichelena
Lew,
I cannot restore to stock. There is no communication in any fashion...
Thanks,
Tom
Return to “General Trinity”
