For some reason I'm unable to install the TCM tune from my trinity. It will read it fine but when i go to install the tune it only installs the ECM tune and never gives a option to install the TCM. When I modify the dablo tune it gives me options to adjust the shift pressure and shift points but when I proceed with installing the tune it doesn't  program the tranny at all and the trinity shows that i have the Diablo tune installed and the TCM is still the original backup.
Im using the latest crom file available for download ( v.1r08g ) So what can I do to get this bug fixed? Do I need to post up a copy of my TCM backup for a updated crom file maybe?
Unable to program the TCM 2012 Silverado 6.2L 6l80
The_Jason_Rogers
2012 Black Silverado CCSB | 6.2L with 6Speed 6L80E | Trinity |
- JonDiablosport
RE: Unable to program the TCM 2012 Silverado 6.2L 6l80
sounds like you are on a cal id that is not supported.
if you can please email your original backup for both PCM/ecm and TCM to [email protected]
also if you can please post your current calibration numbers.
that's not the latest update... there's a newer one within the trinity forum somewhere.... search through the trinity forums for posts from Johan
The_Jason_Rogers
Alright heres the orginal backups and I emailed them to you as well.
Lew I did see another update crom in another thread with a guy having a similar problem but I thought I needed to post up my specific backup to be added otherwise I would of tried that update.
- Calid
- Calid1.jpg (260.18 KiB) Viewed 1811 times
- PCM_647991640866.grg
- PCM Backup
- (67.4 KiB) Downloaded 150 times
- TCM_261871257961.grg
- TCM Backup
- (55.52 KiB) Downloaded 167 times
