check engine lite on code 2285 need help thanks
check engine lite started comming on and it surges and somtimes stalls anyway error code p2285 from predator which says injector control pressure sensor circuit low is this a easy fix or what or does it have to go to dealer 2003 ford superduty 6 liter deisel
RE: check engine lite on code 2285 need help thanks
What revision is this, and what tune are you running?
v8r13 is on the tuner right now ,i put stock tune back on and still have problem i unhooked batterys and then hooked back up and ckeck engine lite went out for how long who knows .i guess this was a ford recall the injector control pressure sensor and the control module wire harrness .and suppossely the injector control sensor is in a real bad location ,i guess this is why my preformance has gone way down and fuel milage surging ,whats your guys opinion thanks
