check engine lite on code 2285 need help thanks
mikevil
Post by mikevil »
check engine lite started comming on and it surges and somtimes stalls anyway error code p2285 from predator which says injector control pressure sensor circuit low is this a easy fix or what or does it have to go to dealer 2003 ford superduty 6 liter deisel
RE: check engine lite on code 2285 need help thanks
What revision is this, and what tune are you running?
mikevil
Post by mikevil »
v8r13 is on the tuner right now ,i put stock tune back on and still have problem i unhooked batterys and then hooked back up and ckeck engine lite went out for how long who knows .i guess this was a ford recall the injector control pressure sensor and the control module wire harrness .and suppossely the injector control sensor is in a real bad location ,i guess this is why my preformance has gone way down and fuel milage surging ,whats your guys opinion thanks
