intune problem
LoneStarChevy1500
intune problem
My intune is freezing up and won't let me use through the USB or the OBD2 cable...It starts to load then 5 secs in between the L and the O in Diablo it freezes, The computer doesn't even see it as a drive.
RE: intune problem
So it never makes it to the main menu?
if so, lets see if you can get it swapped out with the retailer.
RE: intune problem
uhh, the reseller would be me... you know I carry no stock to swap it out with, heh...
no tricks you have to force it to do anything??
RE: intune problem
wait Lonestar... were you able to put the custom tune on it at all??? cuz I know you used the intune before and it worked ok, because you sent me your files for a custom tune....
RE: intune problem
fill out the RMA form to get it sent in to diablo to check it out/fix it...
https://www.diablosport.com/index.php?m ... ay&pid=108
RE: intune problem
Here same problem my INTUNE freeze and won't turn on after initial screen appear look like don't find nothing inside a send a ticket to tech support please let me know a ssoon as you can
