Sonnax 06' Ram - Huge Improvement!
Just thought i would share with everyone. I just got a new Sonnax transmission line pressure booster connector yesterday. I'm using that in conjuction with the performance transmission selected on the Diablo 93 oct tune. I am amazed at the kind of increase in launch and shifts i'm getting. Granted i have read that sometimes the effects will lessen over time from the adaptives, but i can always reset those. Well worth the 50$ and less than 5 mins to install. I've been hesitant on getting one, but now that i have it -would never uninstall.
2006 Dodge Ram 1500 4x4 CrewCab
5.7 Hemi w/ Deleted Fan Mod / CAI / 170 Deg T-Stat / Straight Pipe Exh w/ Cats N Resonators Only
93 BP Gas Running Custom 93 Perf Tune w/ Perf Shift Trans (9r14) / Sonnax Trans Booster
RE: Sonnax 06
be careful using a pressure booster with adjustments on the predator. if you get the pressure too high it can blow out the front pump on your tranny.
Re: RE: Sonnax 06
My understanding is that the Canned Tunes don't mess with line pressure. Maybe one of the tech's can verify this for us. I also was told these transmissions are good until about 240 lbs pressure, which i am way under. The last thing i was told is that these trans are good for just under 1000 hp -once again, i'm not even at 1/2 that hp. That was the original reason i didnt buy one, but now that i did there is no looking back.akatoad wrote:be careful using a pressure booster with adjustments on the predator. if you get the pressure too high it can blow out the front pump on your tranny.
RE: Re: RE: Sonnax 06
correct, we dont mess with pressure onthe rams.
ok well i have an 04 and as we all know diablo never got our trans stuff done like they said they would so i didnt know what could be adjusted and what couldnt.
