is there a fix to the bad idel with the cummins i installed the 9r07 and still there but now lopeing at idel
2006 dodge ram 3500 5.9 cummins
2006 5.9 cummins bad idel
RE: 2006 5.9 cummins bad idel
try this:
options/troubleshooting/restore original backup, then reload the tune.
so its got a bad idel with the factory tune. sounds like a non tune issue
07 Ram Hemi 5.7 quad cab 4x4 big horn. 3.92 gears, Flowmaster exhaust and more coming.
mickey
no leeindy it runs fine without the tuner but idels bad with the tuner
ricerocket12s
Iv got a 07 5.9 and have the same issue... I noticed mine does it alot more when its cold out (Below 30*) and when I first start it in the AM.
Is that what it's called "loping"? Mine sounded like it was was missing and going to die at an idle.
So guys, really when are you going to get this bad idle fixed? This tuner is not worth having if it is not going to work properly!!!!!!
