crom update crash....
I was installing a crom for my 99 7.3l the old 79r1 or something because i had updated it to the new version and it still would not work, and the updater crashed and now i can't even load up to the main screen and the updater cannot find the predator to install a crom.... what can i do????
RE: crom update crash....
When your predator boots up what does it say ? (booting pstroke 73 or booting ford_7_3). This determines which revision you update into the predator.
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
Diablosport Inc.
Tech Support
it says booting ford_7_3,
and i cannot get to the main menu, it says application missing
In your DSDownloader, select "Options" and turn the AutoConnect off. Then select "Options" again and turn Legacy Connect on. Then, manually set the COM port and Baud Rate in the top left corner. Hit "Express Tune Mode" at the bottom and you will see the "Send CROM file to Predator" button. The update you were putting in is probably 8r05. You want to use the 7r19dZ. There are two different versions of the tool.
Christy High
lurker.
lurker.
I went to put in the 7r19dz crom file and now i get a message cannotr load ford_7_3 application into ford_7_3_128k tool... am i trying to install the wrong crom file? and if so will the other crom file allow my to program my truck without issues?? i updated it to the 8r05 crom after i first got my programmer because it gave me a message saying vehicle not in database... so i updated it to the 8r05 and it gave me the same message... i then tried putting the 7r19dz on and this happened...
Send me an email to [email protected] and I will send you the .crom file that you need.
Christy High
lurker.
lurker.
It should be good to go now.
