thanks kw5.9
2007 cummins
2007 cummins
thanks kw5.9
- madmanwithmouse
RE: 2007 cummins
Uhh... you mean clutch?i am noticing my transmison slipping
Either gotta replace the clutch or use a lower tune
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
my bad!! you are right, i just tuned it to the tow and no slippage!!! But when I flip the switch on my power puck to the 50hp it will slip but not quite as much as befor. Has anyone priced out a south bend clutch, just the clutch, no labor? is there anybody in the san antonio area running this combo on a stock truck?
Dodgezilla
You will need the clutch, solid flywheel, and upgraded hydraulics. I paid about $1200 for all that plus installation. Mine is the CON OFE and it holds all the power my truck can make....
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
I thought so, its getting worse even on tow mode from a 60mph punch i am still getting slippage, now i am even worried about down loading anything now< i dont want to have to wait for all these up grades, i have the puck but i cant stack'em to many pony's for rhe stocker, any cheap fixes for now untill i do the whole nine yards?
thanks
thanks
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
Dodgezilla
Sure. I'll sell you my stock clutch assembly with only 14000 miles on it.......
No fix that I know of. I slipped mine a couple of times but it never slipped on the tow tune no matter what I did.....
Dodgezilla
The South Bend holds the power while the stocker won't. Not much difference other than the SB being slightly harder to push in on the pedal....
There is more to enabling high idle on a 6-speed than just putting a tune in. There is a wire in the ECM that needs to be grounded..
Dodgezilla
Mine holds my 450hp just fine. Plenty of guys are putting down 500hp+ with the same exact clutch. My truck is probably putting down about 20-30 more hp than yours due to my bigger turbo. I would say you would be fine but you may want to get the South Bend FE clutch. It's still a single disc clutch but it is rated to hold more power than the OFE that I have...
I am happy with the power I am currently making. if you think you will want more power in the future then do yourself a favor and get the better unit.....
South Bend makes great clutches but if your still wanting a clutch that will support 500-600hp but not spend as much cash I would consider ValAir clutches. Great clutches at a great price. If your interested I can try and get ya a good price on one.
2003 Dodge 2500 Cummins, 6-speed, straight pipe, DS Predator and puck, K&N Cai
i will check them out online, are you running one right now, i wont change untill this one wont go any more, i just keep my foot out of it untill i need it, and then i can only use maybe 1/2 of my pedal.
thanks for all the info
