trinity not saving original backup
kojack
Post by kojack »
I have a 2002 5.3 silverado just got my trinity in updated it, plugged it in and it won't save original backup. Gives this error PCM: error prepare read (-1). Any ideas on why this is happening the truck is stock as far as I know.
kojack
RE: trinity not saving original backup
Post by kojack »
Also I did some reading here on the forums and found similar problems and the solution being to unplug anything aftermarket from the vehicle. I unplugged my stereo and amp still no luck. I have LED aftermarket taillights, corner lights and HID headlights could this be something else causing the problem?
anything thats tied into the stock harness can be an issue...
JoshHunt
Post by JoshHunt »
I am having the exact same problem with my 02 gmc Sierra 1500 with a 5.3, I have a clarion sterio deck, wired for subs but there is non in it, I have halo headlights and after market tale lights also that the previous owner put in, I put a k&n intake and poweraid throttle body spacer in, as far as I know everything else is stock
kojack
Post by kojack »
I hadn't messed with my trinity since April, woke up this morning decided to download the latest update tried it out and it worked perfectly.
good to hear.
Re: RE: trinity not saving original backup
JoshHunt wrote:I am having the exact same problem with my 02 gmc Sierra 1500 with a 5.3, I have a clarion sterio deck, wired for subs but there is non in it, I have halo headlights and after market tale lights also that the previous owner put in, I put a k&n intake and poweraid throttle body spacer in, as far as I know everything else is stock
disconnect the aftermarket harness thats being used to connect the stereo to the trucks harness...
Return to “Trinity GM Gas”
