Board index (Legacy) Predator Technical Discussion Predator Ford Diesel "This tool is not licensed for use with this vehicle"
I just got my 99 f350 7.3 with a predator serial: 9007218 part:u7170 version: v.9r04( i think, my screen is scratch to hell and hard to read). I was having some issues with the truck and I was thinking it might be the tune so I set it back to stock. well it didn't help it actually ran worse. I tried to re install the tune and it said "This tool is not licensed for use with this vehicle" am i installing it wrong? or did I mess something up? first time using a Diablo
did you try it in another vehicle at any point?
561-908-0040x4
Nope. I literally tried to reinstall it in the same truck an hour after putting it back to stock
options/show last tune written, what does it say?
561-908-0040x4
Original backup then I hit continue
Calid:Mx
Vin:
please give us a call tomorrow with the tool powered up and we'll reset it for you.
561-908-0040x4
What info will I need when I call?
just tell them Mike L told you to call to reset the tool ;)
561-908-0040x4
Ok reset my tool with no problem. Thanks guys. Next question can or how do I change my tire size on it? Sorry if this a dumb question. Lol
No can do.... :(
The 7.3 models do not support tire size changes, as thats done through the ABS module...
561-908-0040x4
Ok I'm dumb but does that mean the truck can't be adjusted for tire size or just not with this tuner? Sorry
right, the U7170 has no ability to modify the tire size on a 7.3
561-908-0040x4
Ok truck ran great drove around for about an hour and then let the truck sit(off) for about 2 hours an I just went to get in the truck I started, ran for like 10 sec then stalled out. Then it won't start up at all just crank.... Anything with the tune or probably somthing else with the truck????
the tune cant change, so...it is 99% something with the truck itself.
Any codes?
561-908-0040x4
Im having the same problem ive been in the line for and hour now.. How i reset it??
Next
Return to Predator Ford Diesel
