Torque Management on 05 dodge ram 1500 4.7l
My intune is upto date according to update software, i installed the diablo tune no customized parameters and from a dead stop there is still no power for about 4 sec. according to my research on these forums i believe T.M. is still enabled. What do i need to do to remove the T.M restrictions.
Re: Torque Management on 05 dodge ram 1500 4.7l
can you post up the backup and last tune written files please?
here they are.
- TCM_56028953AEA_LastTuneWritten.drg
- (115.46 KiB) Downloaded 209 times
- TCM_56028953AEA_Backup.drg
- (115.46 KiB) Downloaded 241 times
can you post the PCM tunes please?
What do you mean by pcm tune those were taken off of the intune tune folder
heres my info.xml file if that help
- info.xml
- (482 Bytes) Downloaded 311 times
thats all you have there?
please post the info.xml file as well.
Attached on last post
So I am guessing that tech support has no answer for this which is why their has been no reply at all...Thanks for the customer service.
Still waiting for the PCM tunes...
- Oldsaltydog
You need to send them the PCM tunes they are what control your engine and make it run
Oldsaltydog
2007 corvette c6
2007 corvette c6
I have posted everything that was able to be transfered from to tuner to the computer there were no other files.
go back and restore the stock tune, then try reloading the tunes, does it ask you to update the PCM?
Ok After retuning stock tune and tuning I forget i think diablo tune here is the pcm
- PCM_56028942AF_LastTuneWritten.drg
- (57.69 KiB) Downloaded 259 times
- PCM_56028942AF_Backup.drg
- (57.66 KiB) Downloaded 332 times
What part of this poor guy's original question was not English enough to understand?Andrew.S wrote:What do you mean by pcm tune . . .
So all other post have a answer...is there a reason mine hasnt been pcm tunes have been uploaded and downloaded.
