2008 GMC Sierra - No TCM Support
FE3XCLONE
Post by FE3XCLONE »
2008 GMC Sierra 1500 SLE
5.3L/4sp trans
Doesn't appear to have TCM support in my trinity and could use some help.
2008_GMC_Original Tune File.grg
(59.35 KiB) Downloaded 278 times
Andrew
Re: 2008 GMC Sierra - No TCM Support
Are you using the latest software update?
FE3XCLONE
Post by FE3XCLONE »
Yes. I just downloaded it to the tool tonight.
Andrew
it should save a copy of the stock tcm tune so you can send it to us...
FE3XCLONE
Post by FE3XCLONE »
Mike, I attached what it saved for my original tune in my post above. Will that work?
Andrew
you renamed the file, is it a TCM or PCM tune?
FE3XCLONE
Post by FE3XCLONE »
To my knowledge it was both. On the tool it called it Original (PCM/TCM) backup. It didn't have a separate TCM file.
Andrew
they are separate files, one called PCM_xxxxx and one called TCM_xxxxx
Mike.. have him on IM now...
no, it did not save a TCM original backup file... only the PCM file....
what revision?
latest.. just did updates last night when I was workin with him...
had him update to 2.2.2.6 dsdownloader, restore his backup, connect trinity, fire up DSD, and it updated trinity
weird.
post the vin please and I'll ask Johan to check it out.
FE3XCLONE
Post by FE3XCLONE »
Okay, finally figured it out. Apparently the tool didn't download all of the updates last night.
When I updated it last night it had 4 updates. When it was finished I figured that was it.
Tonight I took Lew's advice and reinstalled the original tune then I plugged the tool back in to see if it would find anymore updates. To my surprise it did and began downloading.
After that I took it out to the truck and now had the TCM options. Sent Lew the PCM and TCM files so we should be all good now.
Thanks for the help Mike and Lew!
Andrew
bahndrvr
Post by bahndrvr »
Hmm, wonder if this is my problem as well, talking with Mikel on the phone and Vas on email, emailed my backup tune to Vas - he said it does not have my TCM file, saved it as PCM/TCM like this one - my tool is updated.
My main problem is the backup error so i can't return it to stock to update again and see if there are pending updates even though my tool says its up to date, would make sense to me.
Hope to get it straightened out soon)
Return to “Trinity GM Gas”
