3.5 long term and 6.0 short term knock
mattyj724
Re: 3.5 long term and 6.0 short term knock
Post by mattyj724 »
here is the xml file.
info.xml
(466 Bytes) Downloaded 175 times
all up to date...
mattyj724
Post by mattyj724 »
thanks. did you look at my stock log by any chance. i compared them both and still not sure what is causing all the long term knock,. can you tell from the log of the tune?
needs some fuel added...
mattyj724
Post by mattyj724 »
wish i could, every time i change something in the tune whether it be the throttle or fuel, or both, it fails to right!
post the last tune written and I'll make you a tune for now...
mattyj724
Post by mattyj724 »
Thanks.
PCM_68139871AD_LastTuneWritten.drg
(73.03 KiB) Downloaded 158 times
mattyj724
Post by mattyj724 »
also here is the log that i did with this tune. the Long term knock is not as bad. but still there. i pulled fuse 2 thinking that resetting the addaptives would help. who knos
54968_00diablo93.log
(523.99 KiB) Downloaded 167 times
heres 2 new files, one with 5 percent added, one with 10% added:
pcm_68139871ad_10percent.drg
(67.77 KiB) Downloaded 164 times
pcm_68139871ad_5percent.drg
(67.77 KiB) Downloaded 173 times
mattyj724
Post by mattyj724 »
mikel wrote:heres 2 new files, one with 5 percent added, one with 10% added:
Added fuel or Throttle? i know we mentioned both in the above post somewhere. ill try them out and log. Thanks
just fuel for now, lets sort out the KR first :)
mattyj724
Post by mattyj724 »
mikel wrote:just fuel for now, lets sort out the KR first :)
i agree, just checking
mattyj724
Post by mattyj724 »
so i installed the 10 percent one last night, everything went smooth. i logged it on the way to work today, it was raining its ass off so not able to really drive her hard. Also the first time driving her in the rain since the tune and removal of most of the TM. :drivingbad: puckered up a few times. lol will post logs when i get home!
mattyj724
Post by mattyj724 »
Here are the 2 logs. both show some short term knk, and zero Long term. the towork file is first then the to home i was able to go WOT a few times.
Also i saw my intune updated today. do i need to reload the tune you sent me? id rather not unless it will make a difference!
54968_10%tohome.log
(510.77 KiB) Downloaded 169 times
54968_10%towork.log
(357.81 KiB) Downloaded 166 times
no need to reload it.
logs are much better....0 LT is a good sign, I think you are in good shape :)
