just received my intune plugged it to my BC and got updated with 1r03h.
i connected the intune to the vehicle went to install calibration update. Got to 99%, and asked to do a key cycle. Key off, press green check mark. Fine. Key on (no dash lights came on btw when i turned key on), pressed green check mark. Tool tells me "an error occured loading calibration tune." Dash lights then come back on. Tool recycles and is in recovery mode. Wants to only write calibration tune at this point. Tried about 5-6 times and exact same results
engine light is on after this issue.
intune now is stuck in recovery mode ..... the car failed to be tuned
Plz help... Or if there is any way to tune the vehicle with any firmware for the time bean.
Seems the new update 1r03h has issues as per the user reports in the forum
hope this will help
<?xml version="1.0"?>
-<tool_info> <main svn="5947" sw_rev="1r03h" full_version="InTune-1r03h 02/25/2013 05:23:14 PM"/> <registration status="1" sn="IGR1786-2"/> <cal_id PCM="68004309AD"/> <restore bc="0" vin="2B3CJ7DW3AH112162" id="0"/> <system_db vin="1r01c" dtc="1r01a" info="1r01b"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01a" mfr="FORD"/> <db pid="1r01a" mfr="GM"/> <license tuned="0" avail="1"/> <updates count="2"/> <oem tool_oem="DIABLODCX"/> </tool_info>
2010 SRT8 challenger 6 speed intune issue
- 20130303_171921.jpg (2.38 MiB) Viewed 1790 times
- 20130303_171829.jpg (2.24 MiB) Viewed 1790 times
Re: 2010 SRT8 challenger 6 speed intune issue
please give us a call with the tool powered up in the car.
Xml File attached as requested
-<tool_info> <main svn="5947" sw_rev="1r03h" full_version="InTune-1r03h 02/25/2013 05:23:14 PM"/> <registration status="1" sn="IGR1786-2"/> <cal_id PCM="68004309AD"/> <restore bc="0" vin="2B3CJ7DW3AH112162" id="0"/> <system_db vin="1r01c" dtc="1r01a" info="1r01b"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01a" mfr="FORD"/> <db pid="1r01a" mfr="GM"/> <license tuned="0" avail="1"/> <updates count="0"/> <oem tool_oem="DIABLODCX"/> </tool_info>
- info.xml
- (466 Bytes) Downloaded 127 times
the dcx tool will not work on a 2010.
Thanks Mike for your assistance the issue has been resolved after swapping the tuner .
