2012 Dodge Challenger 3.6 Intune Problem?
Oconer
Post by Oconer »
Tried tuning vehicle and says i need to update the software which i have already, what do i need to do?
Re: 2012 Dodge Challenger 3.6 Intune Problem?
the update was removed late yesterday to resolve an issue with different vehicles.
Post a copy of the info.xml file from the intune drive please.
Oconer
Post by Oconer »
how would i access that im using MAC
go to the intune drive and the file is there...
Oconer
Post by Oconer »
<tool_info>
<main full_version='InTune-1r03i 05/06/2013 01:43:25 PM' sw_rev='1r03i' svn='6219'/>
<registration sn='CIJML64-1' status='0'/>
<cal_id PCM='68078638AF' CM1='05150729AEkc3l0'/>
<restore id='0' vin='2C3CDYAG7CH206593' bc='0'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01c'/>
<db mfr='DCX' tune='1r01b' pid='1r01a'/>
<db mfr='FORD' pid='1r01a'/>
<db mfr='GM' pid='1r01a'/>
<license avail='1' tuned='0'/>
<unsupported calid='68078638AF' vin='2C3CDYAG7CH206593' oem='DCX'/>
<updates count='1'/>
<oem tool_oem='DIABLODCX'/>
</tool_info>
email sent...
Oconer
Post by Oconer »
it is saying "PCM Calibration for 23CDYAG&CH206593 might need an update. Check for a Calibration Update?"
do as it asks :)
plug it into the pc, let the updater run, and it will download the cal update.
if not, attach a copy of the actual info file here please.
Oconer
Post by Oconer »
Firmware Info:
Application: 1r03i
DCX Tune Db: 1r01c(ok)
DCX PID Db: 1r01a(ok)
FORD PID Db: 1r01a(ok)
GM PID Db: 1r01a(ok)
DTC Db: 1r01a(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
Oconer
Post by Oconer »
info
Oconer
Post by Oconer »
now its saying cant update till registered, how do i do so on mac
Oconer wrote:now its saying cant update till registered, how do i do so on mac
drag/drop the reg file to the intune drive, and let it reboot, that will register the tool.
Oconer
Post by Oconer »
is it normal when i drag and drop the intune reboots then it loads back up but there is nothing in the intune drive
Oconer
Post by Oconer »
Glad I'm not the only one with this issue, hope it will be resolved soon
Oconer
Post by Oconer »
Same deal here man 450 hope it's all worth it once its up and going
