2012 Dodge Challenger 3.6 Intune Problem?
Garza
Re: 2012 Dodge Challenger 3.6 Intune Problem?
Post by Garza »
Cman71 wrote:Not impressed at all.
Just loaded it in this morning with the diablo tune, bumped the throttle booster up to 12, cant feel any difference in car, still wont light the tires up even though I was told prior to buying that this would eliminate the torque limit and the throttle booster would make the car come alive as well, also, was told that I could adjust the shift firmness, WRONG, was told this morning that if I have the 5 speed, I could, well I have the 5 speed and told the tech that and then the reply was "might not be updated yet", thats not what you told me on Monday before I dropped the $450.
Most likely being sent back for a refund, not happy at all.
Have you done any upgrades to your car? Do you drive a charger?
SuaveRT
Post by SuaveRT »
1. Make sure you have 91/93 Oct gas in it.
2. Choose modify tune.
3. For the v6's you must go to 20. There is a difference between 12 and 17, and 17 and 20. Each step you will be able to tell. To max everything go to 20 on throttle boost.
4. To tell right away drive in autostick first. Driving in "D" you won't feel as much due to the re-learn of your driving with tune now on.
Hope this helps!!
Grandpa
Post by Grandpa »
Take the traction control off. You will light up the tires, but your brakes won't hardly stop the car. So be careful with traction control off. Once you cycle the key to off your traction control will come back on. Recommend just using the traction off button in dash.
hadley
Post by hadley »
Hi all I am having this problem... Got the PCM cal error message in the car- so went back to PC, opened DS software but my intune DCX will NOT connect to the software.. welllll that would be because the driver install failed and I cannot for the LIFE OF ME get them to work... So here I am
I am running Windows 8. I followed the step-by-step for driver install on windows 8 and it did not work.
I got this message
Any help? :(
RTS001
Post by RTS001 »
Did you have the subfolders checked?
I got past that point then, when the thing is plugged in and I click update tool it starts looking for a file on my computer. I don't know why there just isn't a link on this website to the file...
Plus I am using a trinity. Seems all the talk is in DCX forum.... :( Very confusing.
hadley
Post by hadley »
Yes I absolutely had all the subfolders checked.
Tried this like 6 times.
THEN tried it all from scratch on a completely different PC with Windows Vista............ driver's wouldn't install on that either!
I am so beyond frustrated and I am usually pretty good with computers......
onthe vista pc, for the driver install, simply right click the intune exe in the diablosport cd rom folder and select run as administrator.
However...the driver is not needed for anything but live streaming data to the PC, it is not needed for updates, at all :)
Grandpa
Post by Grandpa »
Can you update the traction control disable on the Challenger 3.6L.
You have hardly any brakes to stop when you disable the traction control.
It disables everything.
what are you asking exactly?
disabling TC takes out ABS as well, that cant be changed :)
Grandpa
Post by Grandpa »
It was like I had no power brakes at all. Could not hardly stop the car at over 50mph.
Has anyone else tried driving with the tracion control disable on a 3.6L?
SuaveRT
Post by SuaveRT »
Grandpa, most disable traction control for strip use only. Others disable because they are so use to driving older cars that without abs.
SuaveRT
Post by SuaveRT »
Hadley sent you a pm
quazz2727
Post by quazz2727 »
I tried loading says intune in recovery mode -will not install-cannot restore vehicle settings -now check engine light is on -can't go any further - stuck!!
SuaveRT
Post by SuaveRT »
Do you have a push button?
quazz2727
Post by quazz2727 »
yes I have push button but I removed it and used the key
