06 Ram rev & shift points
speedy
Post by speedy »
I have installed my trinity on my 06 ram and i really love it. I want to raise the shift points and rev limiter a little and the settings i choose are not staying with any of the canned tunes i run. I chose to raise the rev limiter to 6,200 then raise the 1-2 & 2-3 shift points to 6,000. I went out for a test run and the shift points are still stock. This is bothering me that something may be wrong. Is there a fix for this?
Brandon
PS. I do have custom tuning for trips to the drag strip and had these parameters raised by the cmr dealer but i would like these to be changed on the canned tunes when running the highway with 87 octane fuel. This is where my issues lie.
2006 Ram 1500 quad cab 4.7L
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
72mm F&B Throttle body
Re: 06 Ram rev & shift points
load the tcm tune with those changes then export the last tune written and post it here please.
also, what revision is the tool on currently?
Actually....FWIW, you can load a custom tcm tune with a canned PCM tune if you want... :)
speedy
Post by speedy »
ok i'll get that info for you. I did see that the custom tcm tune was available but the thing with the custom tcm tune the shifts are very quick and firm and my wife complains about them :twisted: .. but i have to keep her happy.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
Tool revision is 1r09i
I'm currently running the 87 octane tune but would this apply across all tunes?
Also i noticed adjusting the part throttle down shifts do not have any affects either. Rev limiter is also not adjusting correctly. Holding 1st gear it hits the rev limiter at around 5900. I believe i had set it at 6200 to accommodate for the higher shift points. I'll include the pcm file just in case.
PCM_56029199AF_Perf_87oct_modified.drg
PCM file
(3.25 KiB) Downloaded 254 times
TCM_56029223AE_Perf_Trans_Tune_modified.drg
TCM file
(1.25 KiB) Downloaded 278 times
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
Bump
Can anything be done?
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
sorry, can you post the TCM custom tune as well?
speedy
Post by speedy »
This is the custom trans file.
Edit:It has come to my attention that it is possible that even the custom tune files arent able to be adjusted as well. I contacted hemifever where i purchased the trinity from. He says that he has seen it before where the tuner does not alter any of the changes made. I made a quick run on the way home earlier with one of his ecm & tcm custom tunes and infact the rev limiter, and shift points seem to be the same as the canned tunes.
hf-tcm.drg
(115.37 KiB) Downloaded 204 times
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
I called in and have one of the techs looing into this. Hoping there is a fix..
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
Just checking back in. Have you guys figured out anything on my issue? I haven't heard anything back from the tech i talked to.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
This is what I am seeing when I go into change the wot shift points.
It doesn't matter what rpm I select it doesn't hold. it reverts back to what you see in these pics.
Also here is what a few part throttle upshift and downshifts look like. Something is not right. All of them look like this.
UPSHIFT:
Downshift:
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
So i have not heard back from anyone. You guys haven't forgotten about me have you?
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
whats the revision onthe tool?
speedy
Post by speedy »
revision is 1r09i. I had already posted that above.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
