I only have 2 options for tune (diablo and 91 tune) is there an update? For my 11 charger rt
Also is the diablo tune the 93 tune?
I loaded the 91 tune for now, and with it every time i go to modify any parameters loading the tune will error out
91 octane tune
Re: 91 octane tune
So i cant modify any parameters with 91 tune, frustrating
Re: 91 octane tune
I have gathered the diablo tune is a 93 octane
I hope i wil be able to tune it with adjusted parameters by using the doablo tune
Like i said with the 91 tune i cant modify any parameters
Re: 91 octane tune
dont adjust tire size or trans stuff, but the tune based params should be able to be adjusted when you load the tunes.
Re: 91 octane tune
I would like shift firmness increased and traction control enabled
Re: 91 octane tune
I switched to 93 diablo tune and if i adjust parameters the tune wont load
Re: 91 octane tune
make those changes through the quick adjust menu
Re: 91 octane tune
How to load a tune to not error out and be forced to reload the stock tune.
A. Load the tune you want BUT DO NOT adjust and parameters when prompted before loading the tune. Just load the tune to start with.
B. After tune has loaded and your intune tells you it's ok to disconnect, hit the continue button.
c. From your home screen select modify parameters. Make your adjustments and follow the key off/on prompts to save.
d. When backing out the intune will ask you if you want to now load your already loaded tune. Hit X to cancel. It will then tell you it's ok to disconnect.
E. Congratulations, you're done modifying your Tune.
