Board index inTune i-1000 Technical Discussion inTune DCX (i-1000-DCX) 91 octane tune
91 octane tune
Post Fri Jul 12, 2013 12:01 am
I only have 2 options for tune (diablo and 91 tune) is there an update? For my 11 charger rt
Also is the diablo tune the 93 tune?
I loaded the 91 tune for now, and with it every time i go to modify any parameters loading the tune will error out
Post Fri Jul 12, 2013 12:02 am
So i cant modify any parameters with 91 tune, frustrating
Post Fri Jul 12, 2013 7:03 am
I have gathered the diablo tune is a 93 octane
I hope i wil be able to tune it with adjusted parameters by using the doablo tune
Like i said with the 91 tune i cant modify any parameters
Post Fri Jul 12, 2013 8:08 am
dont adjust tire size or trans stuff, but the tune based params should be able to be adjusted when you load the tunes.
561-908-0040x4
Post Fri Jul 12, 2013 8:44 am
I would like shift firmness increased and traction control enabled
Post Fri Jul 12, 2013 3:04 pm
I switched to 93 diablo tune and if i adjust parameters the tune wont load
Post Fri Jul 12, 2013 3:05 pm
make those changes through the quick adjust menu :)
561-908-0040x4
Post Mon Jul 15, 2013 3:48 pm
How to load a tune to not error out and be forced to reload the stock tune.
A. Load the tune you want BUT DO NOT adjust and parameters when prompted before loading the tune. Just load the tune to start with.
B. After tune has loaded and your intune tells you it's ok to disconnect, hit the continue button.
c. From your home screen select modify parameters. Make your adjustments and follow the key off/on prompts to save.
d. When backing out the intune will ask you if you want to now load your already loaded tune. Hit X to cancel. It will then tell you it's ok to disconnect.
E. Congratulations, you're done modifying your Tune.
Return to inTune DCX (i-1000-DCX)
