P061B error
P061B error
Hi, i have this tune, but the wrench light come on with this error p061B and P2106. What is the problem?
My car is a Ford Mustang V6 4000 cc, 2005, with bbk cai, bbk throttle body 70 mm, shorty headers.
- 91R-R2.frg
- (960.13 KiB) Downloaded 272 times
Re: P061B error
Could you please post your original backup?
Insert Clever comment here...
Re: P061B error
Ok, this is my original backup!
Why do I have the P061B error? I have noticed that if the tune is lean, it doesen't appear, but when they correct the tune adding more fuel, the P061B comes on...
- FBBS2B2.frg
- (960.25 KiB) Downloaded 291 times
Re: P061B error
also what revision is on your predator? top right when it's powered up.
Re: P061B error
Othe original backup is the same before and after updating the predator?
I have an original backup saved on my pc. I have updated the predator but I never replaced the original backup saved on my pc. When I did a custom tune I sent the original backup saved with old revision of predator. Is this the problem about my error?
Re: P061B error
I go to ford, and i update my pcm, but i have the same problem. I turn on the car, the rpm go to 2000, put the automatic transmission in D, and wrench light come on with p061B and P2106...
i attach the my new original backup, and my custom tune. can you check this?
- 91S-R7.1.frg
- (960.18 KiB) Downloaded 272 times
- FBBT057.frg
- (960.25 KiB) Downloaded 294 times
Re: P061B error
Give that a try.
- fbbt057_R2.frg
- (960.14 KiB) Downloaded 293 times
Re: P061B error
I try your tune, if i go slow the car doesen't have any problem,but when I press hard the gas pedal the P061B and P2106 come on...
on the attachment you can find the last tune written (your tune). What is the problem?
- FBBT057_custom.frg
- (6.25 KiB) Downloaded 287 times
Re: P061B error
Must be something with the torque monitor. Or you truly have something wrong with the TB. Load this.
- fbbt057_r3.frg
- (960.14 KiB) Downloaded 264 times
Re: P061B error
I try it seems work!! i drive for some miles and i don't have any errors!
what can you do??
what can you do??
Re: P061B error
What can I do about what? I don't understand.
