Can't read troublecodes U7131 06 Dodge Diesel
bigsparkydog
Post by bigsparkydog »
I have an '06 Dodge Ram 2500 Cummins Diesel 4x4. I am using the Predator U71731 Economy Performance Tune. I popped up a check engine light when passing a vehicle today on a 2 lane road. When I try to scan the code the product says "trouble code not found" . I followed the instructions in the manual and the onscreen instructions. I tried it several times including when the check engine light went out after several restarts.
RE: Can
Will the Predator clear the check engine light?
bigsparkydog
I didn't clear the code because I wanted to know what the fault was. The check engine light goes away after several engine restart.
The code may be a non-'P' code, meaning it could be something related to a non-powertrain issue.
The Predator does not always have the ability to read non-'P' codes.
gehmann
06 dodge diesel, 5.9, what's the stock horsepower of my truc
Post by gehmann »
u7131, need new nozzels what size do I get? Want stock! I put 165nozzels in and there to big, (blowing smoke even at idle) will sell cheep. Also need torques on injector hold down and down tube holders, and rocker arms bolts.
Thanks GREG
06 DODGE DIESEL DUALLY 5.9
