06 Ram rev & shift points
Re: 06 Ram rev & shift points
speedy wrote:
mikel wrote:where do you want the shift points set?
I'm sorry, I'd like 1-2 & 2-3 wot shifts @ 6200rpms
load this file. if the tool asks you if you want to reset parameters for the tcm, choose yes, and load this up, let me know.
speedy
Post by speedy »
I don't see an attachment on your post.
2006 Ram 1500 quad cab 4.7L
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
72mm F&B Throttle body
speedy wrote:I don't see an attachment on your post.
oops :)
tcm_56029223ae_tperf_6200.drg
(115.44 KiB) Downloaded 420 times
speedy
Post by speedy »
Thanks I'll try it out.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
UPDATE: I loaded the tune this morning and reset all parameters. I didn't have much time to run & test it like i should have but i was able to see where i was shifting at WOT. The 1st-2nd shift hit close to the 6200 mark but the 2nd-3rd shift was only around 5500-5600rpms.
What is causing the tcm user adjustments to not apply to the tune? Is there something wrong with my pcm and tcm? I had originally thought it may have been my Trinity so i tried a brand new Intune but the same exact thing was happening. The rev limiter or Transmission user adjustments did not apply to the tune.
I had threw up the idea having the tcm and pcm reflashed or updated but the service tech at the dealership says it wont help.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
can you log it so we can see exactly where its shifting?
speedy
Post by speedy »
mikel wrote:can you log it so we can see exactly where its shifting?
Here is a quick log for first and second shifts
SHIFTS.LOG
(39.93 KiB) Downloaded 403 times
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
Just throwing this out there but I get the same results on the tune from my CMR. He also had issues getting the rev limiter adjustment to apply. Every attempt the limiter would kick in around 5800. The final attempt he raise the park/neutral rev limiter to 6300 and that some how raised the rev limiter in Drive. I was able to shift past 5800 but the shifts never would hit 6200 just like it is now.
Basically I have no TCM control.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
speedy
Post by speedy »
were you guys able to get anything out of the log?
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
does it shift like normal at 5800, or does it hang...?
speedy
Post by speedy »
mikel wrote:does it shift like normal at 5800, or does it hang...?
Its shift normal, no hangs or anything like that.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
white_lightning
Post by white_lightning »
speedy wrote:were you guys able to get anything out of the log?
took a look at your log, and the tune file.
1-2 only spun to 6,053 but should have gone up to at least 6300rpm if all WOT shift triggers are properly set, IMO.
if a shift starts at 6200, you will rev past that a bit before the shift completes.
WOT 2-3 shifts at only 5546rpm, that's at least 700rpm low.
do you have an aftermarket cam? 6200rpm is a bit high for a stock cam.
problem is in the shift tables, IMO.
gonna post some stuff for mikel to add to your tune. mikel fixed the tune he posted so it can't be edited by anyone else.............
other option is you can email me at the email in my sig, and we can start over with a new TCM tune. a lot of the changes in your tune are a bit off, IMO.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
white_lightning
mikel (or other Diablo tech),
was not able to fine template 56029223ae, so used an original backup from another 06 ram.
changes to add into speedy's tune are located here in the attached tune:
functions>transmission upshift in overdrive
scalars>transmission upshift
TCM 06 Ram_56029224AF_WOT shift changes for speedy.drg
(115.4 KiB) Downloaded 336 times
Last edited by white_lightning on Mon Nov 04, 2013 12:07 pm, edited 1 time in total.
My Ride:
white_lightning
speedy,
DO NOT try to load the tune I just posted, it is from another 06 ram, and has wrong vin#.
it could mess up your PCM if you tried to load it in your truck.
please wait for mikel (or other Diablo tech) to add the key changes into the tune he posted a while back.
My Ride:
speedy
Post by speedy »
Ah I see. No i'm running stock cams at the moment.
I may end up emailing you.
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
