2011 Silverado 6.0 2500HD 4x4
18BKLR
Re: 2011 Silverado 6.0 2500HD 4x4
Post by 18BKLR »
mikel wrote:
XjBilly wrote:Seriously??!!! You're joking right ? I think we've all got a few thoughts about this crap , as the previous 11 pages show
latest update with any unsupported 6.0 2500 files we have received :)
Tells me I the file is in an unsupported format for my tool.
Not sure what is going on. The file that was on there was trinity_gm_can_gas-1t09if_update.crom
thats a trinity update, you cant load that...just let the auto updater run, and click update/check now to get the latest versions.
18BKLR
Post by 18BKLR »
Not sure what is going on. The file that was on there was trinity_gm_can_gas-1t09if_update.crom[/quote]
thats a trinity update, you cant load that...just let the auto updater run, and click update/check now to get the latest versions.[/quote]
updated my tool today
I went in and did a complete restore and then a fresh backup of my origional tune. I then got a screen that said something like TCM calibration missing for my VIN and then it said do you want to do a backup read. I clicked yes and the tool locked up completely as it was looking at the origional backup.
18BKLR wrote:Tells me I the file is in an unsupported format for my tool.
Not sure what is going on[/quote]
the fix for reading the unsupported tcm is coming, should be today.
you can click the x there for now and just tune the PCM if you desire :)
18BKLR
Post by 18BKLR »
you can click the x there for now and just tune the PCM if you desire :)[/quote]
Thanks, I will just wait till I can do the whole install once you have it fixed.
yep, same thing happened to a buddy's truck.. you need to skip (red X) that TCM read when it comes up.. and you will be able to install the ECM tune at least for now...
18BKLR
Post by 18BKLR »
Got the update today.. Now I click yes when it wants to read the TCM settings and it proceeds to do a backup of the original tune. When it gets to this point now it wants to lock up reading the stock tune. Seems we went one step further in the right direction..
Got the update today.. Now I click yes when it wants to read the TCM settings and it proceeds to do a backup of the original tune. When it gets to this point now it wants to lock up reading the stock tune. Seems we went one step further in the right direction..[/quote]hmm...so, it saved the TCM, but then would not save the stock PCM tune?
18BKLR
Post by 18BKLR »
]Tells me I the file is in an unsupported format for my tool.
upda
Got the update today.. Now I click yes when it wants to read the TCM settings and it proceeds to do a backup of the original tune. When it gets to this point now it wants to lock up reading the stock tune. Seems we went one step further in the right direction..[/quote]hmm...so, it saved the TCM, but then would not save the stock PCM tune?[/quote
Seems you are correct
OK, can you post a fresh info.xml file please
18BKLR
Post by 18BKLR »
Here you go..
info.xml
(1.9 KiB) Downloaded 423 times
Here you go..
load this new database and try it again please :)
edit...emailing you the Database.
18BKLR
Post by 18BKLR »
Mike I emailed you the unsupported TCM file. Hopefully that helps you out. I am able to hit the red "X" and tune the truck just no communication with the TCM at this point still.
18BKLR
Post by 18BKLR »
Seems you are correct[/quote]OK, can you post a fresh info.xml file please[/quote]
Here you go..[/quote]
edit...emailing you the Database.[/quote]
I emailed you the TCM file mike, is there a fix for this yet?
Should I sync up yet?
Return to “Trinity GM Gas”
