Why does it keep updateing back to 1r01t
bullfrog69z
Installed the update 1t01t and when I plug it to my computer it keeps updating back to 1r01t and loose tcm support until I reinstall 1t01t back. Will their be a update to fix this issue?
- info.xml
- (2.02 KiB) Downloaded 103 times
Re: Why does it keep updateing back to 1r01t
What exactly is the file you are loading? Typically, when on a test version, the tool will not auto update unless you select check now under updates.
bullfrog69z
Thanks ,, that the problem. I hit check for updates. Will their be a new update for the test version soon.garrett wrote:What exactly is the file you are loading? Typically, when on a test version, the tool will not auto update unless you select check now under updates.
bullfrog69z
Oh. But it doesn't have tcm support in it. ??garrett wrote:technically, 1r01t is NEWER than 1t01t
