Does intune in Neon SRT4 have WOT shift?
djkomplex
Post by djkomplex »
I know the stage1, 2, 3 has the WOT shift feature that cuts fuel when you do a wot shift? I believe it would cut spark and spray fuel while you wot shift.
stroudtom
Re: Does intune in Neon SRT4 have WOT shift?
Post by stroudtom »
Your gonna need another box for that and a boost box as well.
sohfast94
Post by sohfast94 »
IT could easily be added to a production cal... You would have to test it tho.
Insert Clever comment here...
sohfast94
Post by sohfast94 »
There I added them to CMR whenever you post your last tune written I'll add it to your tune and you can give it a try.
stroudtom
Post by stroudtom »
Brian, did you add a WOT shift for custom option?
Can I add that to my tune as well?
sohfast94
Post by sohfast94 »
It's not adjustable in the tool if that's what you're asking. It's in CMR tho.
stroudtom
Post by stroudtom »
So I would have to WOT shift and give feedback so you could dial it in?
sohfast94
Post by sohfast94 »
Wait you're not PCM controlled boost so I don't think it will do anything... It basically holds the wastegate from what I can tell. I don't know if it oscillates the injectors.
stroudtom
Post by stroudtom »
Thanks Brian for clarifying that and sohfast response :)
djkomplex
Post by djkomplex »
I am still tuning my car. Is there anyway you could post it to a stock diablotune for a 04 srt4 and I'll gladly test it. I have a notepad where I write my settings down. I just got my wideband installed and have been tuning.
Is there anyway to enable boost by speed in the tuner or is that a car thing? I filled out the dealer stuff and am still waiting to hear back. I wanted to demo cmr as there aren't any dealers that have the dcx tuner around here and I know a lot of SRT owners that want me to tune their cars.
sohfast94
Post by sohfast94 »
Better off posting your last tune written.
djkomplex
Post by djkomplex »
Yeah, I figured it probably has all my cars Vin and other data. I will pull it out on my comouter when I get home and post it. I will still be able to edit it after you make the changes like my custom tunes so I should be good.
Are you a developer at DS? How hard would it be to add boost by gear to the unit sort of like the avcr did? Set gear 1 @ 2k rpm the car is going 20mph or whatever it is and then just set how much boost to remove from the base setting.
djkomplex
Post by djkomplex »
Here is my last tune written. If you could while your in there, turn off the p0420 code for not having a cat.
I will let you know how the WOT shift works.
Thanks!
PCM_05029415AH_LastTuneWritten.drg
(59.46 KiB) Downloaded 260 times
djkomplex
Post by djkomplex »
Plus I also keep getting codes p1188 and p0420 which I have been getting since I removed the cat.
sohfast94
Post by sohfast94 »
Give this a whirl.
pcm_05029415ah_WS1.drg
(57.72 KiB) Downloaded 273 times
