Does intune in Neon SRT4 have WOT shift?
I know the stage1, 2, 3 has the WOT shift feature that cuts fuel when you do a wot shift? I believe it would cut spark and spray fuel while you wot shift.
Re: Does intune in Neon SRT4 have WOT shift?
Your gonna need another box for that and a boost box as well.
IT could easily be added to a production cal... You would have to test it tho.
Insert Clever comment here...
There I added them to CMR whenever you post your last tune written I'll add it to your tune and you can give it a try.
Brian, did you add a WOT shift for custom option?
Can I add that to my tune as well?
It's not adjustable in the tool if that's what you're asking. It's in CMR tho.
So I would have to WOT shift and give feedback so you could dial it in?
Wait you're not PCM controlled boost so I don't think it will do anything... It basically holds the wastegate from what I can tell. I don't know if it oscillates the injectors.
Thanks Brian for clarifying that and sohfast response
I am still tuning my car. Is there anyway you could post it to a stock diablotune for a 04 srt4 and I'll gladly test it. I have a notepad where I write my settings down. I just got my wideband installed and have been tuning.
Is there anyway to enable boost by speed in the tuner or is that a car thing? I filled out the dealer stuff and am still waiting to hear back. I wanted to demo cmr as there aren't any dealers that have the dcx tuner around here and I know a lot of SRT owners that want me to tune their cars.
Better off posting your last tune written.
Yeah, I figured it probably has all my cars Vin and other data. I will pull it out on my comouter when I get home and post it. I will still be able to edit it after you make the changes like my custom tunes so I should be good.
Are you a developer at DS? How hard would it be to add boost by gear to the unit sort of like the avcr did? Set gear 1 @ 2k rpm the car is going 20mph or whatever it is and then just set how much boost to remove from the base setting.
Here is my last tune written. If you could while your in there, turn off the p0420 code for not having a cat.
I will let you know how the WOT shift works.
Thanks!
Thanks!
Plus I also keep getting codes p1188 and p0420 which I have been getting since I removed the cat.
Give this a whirl.
- pcm_05029415ah_WS1.drg
- (57.72 KiB) Downloaded 267 times
