Speedo off
Speedo off
When I unmarry the inTune from my car (2012 300 SRT8) the speedo reading is off. The speed will read higher/faster than I am actually travelling. I've tried it twice and both times my speedo was off, there's nothing wrong with it when a tune is installed though.
Re: Speedo off
Do you have stock size tires and stock gears?
Re: Speedo off
My gears are stock at 3.06 but I'm running 22" wheels. I know my speedo was off a little after I put on the 22's (without tune) but now it is grossly off. On the freeway it will read at least 20mph faster than I am actually traveling, in the city it will read about 10mph faster.
Re: Speedo off
if you go into the tire size by height menu, what does it default to?
same for the axle ratio menu?
Re: Speedo off
With the tune removed, for some reason the tire height defaults to 38"s. When I go into the axle ratio, it does not show which gear is the default.
Re: Speedo off
I have the same exact issue, when I put my car back to stock, the speedo reads faster than I am going, and I have the stock wheels and gears in my car. I went in, once I re-tuned my car, and put the stock tire size in, and stock axle ratio of 2.65, figuring it could't hurt anything, and now, when I go back to stock, it still doesn't read right anymore. Anyway to correct this? You have to think, if my speedo is reading faster than I am going, the mileage is going to rack up more than what I am actually driving, and that is NOT good for my warranty, some advice would be great, thanks!
Re: Speedo off
While you are right about the mileage accumulating faster than what you have actually driven, it's a relatively small difference that would take quite an extended period of continuous operation to add up to anything significant.ledman wrote:I have the same exact issue, when I put my car back to stock, the speedo reads faster than I am going, and I have the stock wheels and gears in my car. I went in, once I re-tuned my car, and put the stock tire size in, and stock axle ratio of 2.65, figuring it could't hurt anything, and now, when I go back to stock, it still doesn't read right anymore. Anyway to correct this? You have to think, if my speedo is reading faster than I am going, the mileage is going to rack up more than what I am actually driving, and that is NOT good for my warranty, some advice would be great, thanks!
I wouldn't worry about it too much anyway, you have a 100K mile drivetrain warranty. You have plenty of time to get things figured out and corrected.
Re: Speedo off
nuke wrote:While you are right about the mileage accumulating faster than what you have actually driven, it's a relatively small difference that would take quite an extended period of continuous operation to add up to anything significant.ledman wrote:I have the same exact issue, when I put my car back to stock, the speedo reads faster than I am going, and I have the stock wheels and gears in my car. I went in, once I re-tuned my car, and put the stock tire size in, and stock axle ratio of 2.65, figuring it could't hurt anything, and now, when I go back to stock, it still doesn't read right anymore. Anyway to correct this? You have to think, if my speedo is reading faster than I am going, the mileage is going to rack up more than what I am actually driving, and that is NOT good for my warranty, some advice would be great, thanks!
Well, I cannot figure it out, so I am putting my car back on the factory tune,m and taking it to the dealer to have them reset my PCM so the speedo wuill read correct, and when I re-tune my car, I am not going to mess with the tire and rear axle settings, as I don't need to change anything. I did that before, and thats why I think it messed up my factory settings.
