The Vehicle is not supported (300C 3.5V6 2007)
Vladimir5145409
Post by Vladimir5145409 »
Hello!
EGG 3.5L High Output V6 24V MPI Engine
DGJ 5-Speed Auto W5A580 Transmission
Bought a new inTune and tried to install but said it was not support.
All updetes are installed.
Help me please!
E-mail: [email protected]
info.xml
(1.8 KiB) Downloaded 356 times
Last edited by Vladimir5145409 on Tue Apr 01, 2014 10:53 am, edited 1 time in total.
Re: The Vehicle is not supported (300C 3.5V6 2007)
it is asking you to connect to a pc for an update ;)
Vladimir5145409
mikel wrote:it is asking you to connect to a pc for an update ;)
There is no more updates.
info.xml
(1.8 KiB) Downloaded 341 times
Vladimir5145409
Can you give me .drg file with my VIN?
connect it to a pc and it will download the file to your tool automatically :)
it must have loaded it already, go to the vehicle and select tune vehicle/write vehicle and t will prompt you to load the update then you can tune it.
Vladimir5145409
I have European Chrysler 300.
Vladimir5145409
mikel wrote:it must have loaded it already, go to the vehicle and select tune vehicle/write vehicle and t will prompt you to load the update then you can tune it.
.drg from updater has been loaded
Updater said: "This inTune is up to date"
When I plug tool into vehicle, and select Tune Vehicle Write Vehicle, he said "Vehicle is not supported"
post the current info.xml file please.
Vladimir5145409
How can I use this inTune?
If my vehicle is not supported.
Here is file:
info.xml
(1.8 KiB) Downloaded 342 times
Vladimir5145409
I think that my VIN is missing in database, because vehicle produced in Belgium.
Is it possible?
Vladimir5145409
Can you send me .drg file with my VIN?
Thanks!
could you give us a call with the tool powered up in the vehicle so we can attempt to force a calibration update?
Vladimir5145409
mikel wrote:could you give us a call with the tool powered up in the vehicle so we can attempt to force a calibration update?
Thanks for help!!!!
I wrote program in ECU !!!
Return to “General Support”
