The Vehicle is not supported (300C 3.5V6 2007)
Vladimir5145409
Hello!
EGG 3.5L High Output V6 24V MPI Engine
DGJ 5-Speed Auto W5A580 Transmission
Bought a new inTune and tried to install but said it was not support.
All updetes are installed.
Help me please!
E-mail: [email protected]
Help me please!
- info.xml
- (1.8 KiB) Downloaded 356 times
Last edited by Vladimir5145409 on Tue Apr 01, 2014 10:53 am, edited 1 time in total.
Re: The Vehicle is not supported (300C 3.5V6 2007)
it is asking you to connect to a pc for an update
Vladimir5145409
There is no more updates.mikel wrote:it is asking you to connect to a pc for an update
- info.xml
- (1.8 KiB) Downloaded 341 times
Vladimir5145409
Can you give me .drg file with my VIN?mikel wrote:it is asking you to connect to a pc for an update
connect it to a pc and it will download the file to your tool automatically
it must have loaded it already, go to the vehicle and select tune vehicle/write vehicle and t will prompt you to load the update then you can tune it.
Vladimir5145409
I have European Chrysler 300.mikel wrote:it is asking you to connect to a pc for an update
Vladimir5145409
.drg from updater has been loadedmikel wrote:it must have loaded it already, go to the vehicle and select tune vehicle/write vehicle and t will prompt you to load the update then you can tune it.
Updater said: "This inTune is up to date"
When I plug tool into vehicle, and select Tune Vehicle Write Vehicle, he said "Vehicle is not supported"
post the current info.xml file please.
Vladimir5145409
How can I use this inTune?mikel wrote:it must have loaded it already, go to the vehicle and select tune vehicle/write vehicle and t will prompt you to load the update then you can tune it.
If my vehicle is not supported.
Here is file:
- info.xml
- (1.8 KiB) Downloaded 342 times
Vladimir5145409
I think that my VIN is missing in database, because vehicle produced in Belgium.
Is it possible?
Is it possible?
Vladimir5145409
Can you send me .drg file with my VIN?
Thanks!
Thanks!
could you give us a call with the tool powered up in the vehicle so we can attempt to force a calibration update?
Vladimir5145409
Thanks for help!!!!mikel wrote:could you give us a call with the tool powered up in the vehicle so we can attempt to force a calibration update?
I wrote program in ECU !!!
