2007 Magnum 5.7
Put the new rev 93 oct tune in for the first time. The engine fans are on all the time. I'm at 5000 ft and it's 20 degrees out side. I really doubt I need the fans. Wazup?
Fans on always
RE: Fans on always
Try the latest revision, it has the fan temps back to stock.
HemiNewbie
fans on
Mike I downloaded and installed the latest version
Dale
Dale
RE: fans on
I had the same problem. I am working the fire station today but in the morning I will post my fan settings. Since I have changed them, my fan doesn't kick on anymore.
RE: fans on
Here are my fan settings:
Low- 217.39 Med- 226.39 High- 226.39
A/C Off
High MPH HS - 226.39
High MPH LS - 217.39
High MPH MS - 226.39
Low MPH HS - 228.39
Low MPH LS - 217.39
Low MPH MS - 226.39
A/C Off
Low MPH HS - 228.39
Low MPH LS - 217.39
Low MPH MS - 226.39
joeyclutch
I'm running a 180*F t-stat that indicates coolant temps of 185-188*F in the EVIC. According to DS there is a 10*F range between the fan on temperature and the fan off temperature, so to keep the fans from running continuously I'm running my fans @ HS = MS = 207, and LS = 197. I've seen the LS shut off at 189*F.joeyclutch wrote:where should my fan setting be i have 06 srt8 with a 180 t stat cai93 tune
joeyclutch
