says
unable to execute file
c;/program files(x86)/diablosport/dataviwer3.3/dataviewer.exe
create process failed;code 14001
this application failed to start because its side-by-side
configuration is incorrect. please see the application event log
or use the command-line sxstrace.exe tool for more details
What the heck is this i cant install?
I need dataviewer to log for Johan any advice?
Huge issue trying to install dataviewer
Re: Huge issue trying to install dataviewer
Not so huge
Gimme a sec, I'll post the link from the DV section with the fix for this...
Thanks Mike worked, would usually do that after but it wouldnt work. That did the trick.
Now when i click the shortcut to open the program it says,
Another instance of the dataviewer is running.
please alt-tab to that instance and use it (or close it).
Alternately, wait a few moments and try again.
Omg why does this stuff keep happening any suggestions?
thanks in advance.
thanks in advance.
DV doesnt always close cleanly, kill it in the device manager
Is there a patch to get the DV to close cleanly so we don't have to go to the device manager all the time?mikel wrote:DV doesnt always close cleanly, kill it in the device manager
ks
download the latest version from the dataviewer section of the forum
