After updating "Error Code=0x00000386"and is displayed and i-1000 programmer became impossible.
It has not improved, although the 1r03x file was attached.
It was confirmed as instructed but does not work.
http://www.diablosport.com/forum/viewto ... 44&t=47489
I tried the 1t03xa to mimic this forum.
But,Symptoms did not change.
What should I do next step?
Re: "Error Code=0x00000386"
what vehicle?
please post the info.xml file from the intune drive along with any files from the runtime folder.
pacificcoast
Hi Mikel,
We have a 2006 TRAILBLAZER SS.
Please Investigation.
Reagards,
Reagards,
- runtime_05.dbg
- (149.65 KiB) Downloaded 129 times
- runtime_04.dbg
- (149.89 KiB) Downloaded 178 times
- runtime_03.dbg
- (147.7 KiB) Downloaded 201 times
- runtime_02.dbg
- (165.63 KiB) Downloaded 190 times
- runtime_01.dbg
- (148.06 KiB) Downloaded 163 times
- runtime_00.dbg
- (149.64 KiB) Downloaded 228 times
- info.xml
- (2.52 KiB) Downloaded 174 times
Last edited by pacificcoast on Tue May 27, 2014 11:38 pm, edited 2 times in total.
please load the attached file to the intune drive, and let the tool import it, then try it again in the truck.
- GM_TUNES-1t02aa.ITF
- (5.71 MiB) Downloaded 177 times
pacificcoast
Mikel,
I've attached the GM_TUNES-1t02aa.ITF file, but the symptoms did not change.
I tried to test the other new i-1000 .
It was working properly .
Is it possible to format the i-1000 that has a problem?
Last edited by pacificcoast on Tue May 27, 2014 11:39 pm, edited 2 times in total.
Is there a new runtime (_06) now?pacificcoast wrote:Mikel,
Can you post that with the new info.xml file please?
pacificcoast
Mikel,
Please check it.
My Best Regard,
Please check it.
My Best Regard,
- runtime_00.dbg
- (149.64 KiB) Downloaded 165 times
- runtime_01.dbg
- (148.06 KiB) Downloaded 184 times
- runtime_02.dbg
- (165.63 KiB) Downloaded 136 times
- runtime_03.dbg
- (147.7 KiB) Downloaded 166 times
- runtime_04.dbg
- (149.89 KiB) Downloaded 131 times
- runtime_05.dbg
- (149.65 KiB) Downloaded 141 times
- runtime_06.dbg
- (145.66 KiB) Downloaded 148 times
- runtime_07.dbg
- (150.22 KiB) Downloaded 128 times
- info.xml
- (2.54 KiB) Downloaded 123 times
pacificcoast
Would like to ask the reset tool of problem solving if difficult.
Regards,
Regards,
if you would like to try resetting it please give us a call with it powered up ion the truck.
