PCM Calibration might need an update
sdmracing
Post by sdmracing »
PCM Calibration 1J4BA5H1XAL183322 might need an update. Check for calibration update?
I have the latest updates 1r04b. This happened right after the dealer did an update on the PCM. This is for a 2010 jeep wrangler. It doesn't want to go any further. I did the update a few times just to be sure. I cleared the updates from the intune and reloaded them again. Still in the same boat here. Is there something I'm missing.
info.xml
info
(2.52 KiB) Downloaded 351 times
Re: PCM Calibration might need an update
it says the tool is already married to the vehicle, was it not restored before the dealer flashed it?
No5pam
Post by No5pam »
I'm also having the same issue. PCM Calibration for VIN might need an update. Check for a Calibration Update?
I also get, "No ECUs Found. Check ignition key"
It checks for codes, and it knows my VIN. What's the deal?
info.xml
(1.82 KiB) Downloaded 287 times
No5pam
Post by No5pam »
Here's another tidbit of info. I'm trying to set up on a PC. When I look in Explorer, I see my .xml file and three folders. For kicks, I looked on my Mac. I see all the files.
I copied the files to my PC, and they're now loading.
No5pam
Post by No5pam »
it went through all sorts of gyrations, and I get the same outcome: PCM Calibration for VIN might need an update
