U7135 version
msierra519
U7135 version
Post by msierra519 »
Hey all..i am new to this and i just got my predator today..i noticed that this version is 9r12 and there is 9r30 available. what is the difference between these? will i lose something by upgrading?
Re: U7135 version
old tools can only go as far as 9r12....
msierra519
Re: U7135 version
old tools meaning all predators? or are there certain versions of the predator that can support the higher version number? also, why would the option be available in the downloads page under the u7135 if it cant support it?
Re: U7135 version
its available because most newer tools will take it.
go to tool info on the main menu and if it says hardware unknown, 9r12 is the latest.
if it says univ_rev_2, you can go to 9r30, you will lose O2 disable and COT settings if you do.
msierra519
Re: U7135 version
oh ok yeah your right, mine says hardware unknown. does that mean i can never have the option to disable mds?
Re: U7135 version
MDS disable is in there....
msierra519
Re: U7135 version
where? i looked in every option and do not see MDS at all.
Re: U7135 version
after you select the tune choose the option to modify tune...what vehicle are you tuning?
msierra519
Re: U7135 version
Quick adjust? I have a 07 charger Daytona
Re: U7135 version
no, not quick adjust.
msierra519
Re: U7135 version
Ok then where do I go?
Re: U7135 version
msierra519 wrote:Ok then where do I go?
msierra519
Re: U7135 version
After I select the tune and its running I don't have an option for modify tune..just quick adjust
Edit..
I see it now..thank you!
NeoAnderson
Re: U7135 version
Post by NeoAnderson »
Hello, I'm running version 9r23 and would like to update to 9r30. But I'm confused about the requirement of reinstalling my original/stock tune before the upgrade. Does that mean the tune from the showroom five years ago (I drive an '09 Chrysler 300 SRT8). I installed a supercharger in 2010 and now use a customized, non-Predator tune tune. How should I proceed? Thanks.
