2014 Dodge Challenger SXT and Traction Control
Re: 2014 Dodge Challenger SXT and Traction Control
Hi Mike! Can I also get a copy of my tune to turn the ESP turn off on my 2011 Charger RT? If so here is my LTW. Thanks!
this tune is locked, ask your tuner to take care if it for you since he dont want anyone to see his workjosh6980 wrote:Hi Mike! Can I also get a copy of my tune to turn the ESP turn off on my 2011 Charger RT? If so here is my LTW. Thanks!
same problem but on my 2014 charger 3.6lmikel wrote:would you like a customtune for now that will disable TC when loaded?
can u please write me one too?thanks
disabled here.marcaine wrote:same problem but on my 2014 charger 3.6lmikel wrote:would you like a customtune for now that will disable TC when loaded?
Thank you kind sir!!mikel wrote:disabled here.marcaine wrote:same problem but on my 2014 charger 3.6lmikel wrote:would you like a customtune for now that will disable TC when loaded?
rsalgado0520
Re: 2013 Dodge Challenger SXT
Hi Mikel I have no idea of what am doing I got the intune dcx I already updated the intune I already plug that to my car I did the 91 octane tune do I need to adjust parameters I have only a CAI am planing to put a custom exhaust in the near future I did mess around with the throttle boost I move that to 20% and the tire dimensions I put the stock 18s and the axle to 3.06 I have no Idea if the sxt base or sxt plus have the same axle.
please help its the first time I use a tuner and I have no idea on how to play with that I seen that there are custom tunes but what are does? I just want my car to be to the max of what I have
Im also wondering ive heard if you have paddle shifter and sport mode you get a beffer suspension and a different ratio anyone have anything on this?rsalgado0520 wrote:Hi Mikel I have no idea of what am doing I got the intune dcx I already updated the intune I already plug that to my car I did the 91 octane tune do I need to adjust parameters I have only a CAI am planing to put a custom exhaust in the near future I did mess around with the throttle boost I move that to 20% and the tire dimensions I put the stock 18s and the axle to 3.06 I have no Idea if the sxt base or sxt plus have the same axle.
please help its the first time I use a tuner and I have no idea on how to play with that I seen that there are custom tunes but what are does? I just want my car to be to the max of what I have![]()
I'm having the same issue, if you have a chance to do mine i would like to keep all my adjusted perimeters as well. I got the fans and everything where i want them lol. I have the 3.6 btw trying to see if i can at least get a small peel out going. It also fails on me when i try to do any transmission options as well like resetting the learning or whatever.
here you go.gtapro151 wrote:mikel wrote:disabled here.marcaine wrote: same problem but on my 2014 charger 3.6l
Would you be able to disable TC on my tune also please?
thank you that was fast. will this keep awd off to? and do i just drop it in the tunes folder and it will show up when i plug the tuner in car next?
Hey Mike, can you do the same for my tune please?mikel wrote:here you go.gtapro151 wrote: I'm having the same issue, if you have a chance to do mine i would like to keep all my adjusted perimeters as well. I got the fans and everything where i want them lol. I have the 3.6 btw trying to see if i can at least get a small peel out going. It also fails on me when i try to do any transmission options as well like resetting the learning or whatever.
here you go.Dmanw wrote:Hey Mike, can you do the same for my tune please?mikel wrote:here you go.gtapro151 wrote: I'm having the same issue, if you have a chance to do mine i would like to keep all my adjusted perimeters as well. I got the fans and everything where i want them lol. I have the 3.6 btw trying to see if i can at least get a small peel out going. It also fails on me when i try to do any transmission options as well like resetting the learning or whatever.
Thanks! Appreciate it!mikel wrote:here you go.Dmanw wrote:Hey Mike, can you do the same for my tune please?mikel wrote: here you go.
Moparman2015
Hi Mike,
I wrote in another thread asking about this very issue…is it possible to get a tune withe the traction control disabled aswell?
I have a 2011 Dodge Charger SXT 3.6L with a Ram Air CAI running the 91Octane tune….
Thank you in advance
