Trinity locked with 2015 Silverado 6.2
Re: Trinity locked with 2015 Silverado 6.2
We'll post the update here for you when its ready.
What happened to the weekly update that you were going to post , that is going to support my truck?
Attached.
- trinity_gm_can_gas-1r13g_update.crom
- (2.16 MiB) Downloaded 312 times
Tune is not working properly. It has a lag time when you mash down on the pedal and the speed limiter will not turn off!! Have never had such problems with a tuner before. Is there a fix for this ?? Or better yet how about a full refund , since this tuner doesn't do what y'all say it will!!!!!
throttle response should be quite a bit better, can you use the dsdownloader software to extract the tune files and post them here please?
ATTACHED
- PCM_665218668871_Diablo_Tune_modified.grg
- (3.25 KiB) Downloaded 525 times
Original Backup
- PCM_665218668871.grg
- (123.53 KiB) Downloaded 378 times
Please load this tune to the tool and let me know how it responds, I've got your speed limiter disabled in the file too. If it asks to reset adjustable parameters, please select yes.
- pcm_665218668871_diablotune.grg
- (103.59 KiB) Downloaded 336 times
Installed and it runs better. Still hitting the limiter at 99 though. Tried turning the limiter off on the tool and the vehicle started having issues again. Reset the tune and reinstalled the custom tune. Runs fine again. Still hitting the limiter though.
BlackZ71Silverado
gmphillip wrote:Installed and it runs better. Still hitting the limiter at 99 though. Tried turning the limiter off on the tool and the vehicle started having issues again. Reset the tune and reinstalled the custom tune. Runs fine again. Still hitting the limiter though.
If you are having issues, it sounds like you should be speaking with the person that did the custom tune for you. They will be able to change things in your tune that you can not do using the programmer.
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
MBRP exhaust
GMPP exhaust
GMPP CAI
He IS speaking with the person who did his custom tune, Zach did the custom tune for him above.
be sure to reset params when loading the tune to fix the limiter issue.
This was the last tune written to the vehicle. I did choose to reset parameters. Still hitting the limiter.
And has there been any progress in a TCM tune for the 8 speed?
- PCM_665218668871_pcm_665218668871_diablotune.grg
- (3.25 KiB) Downloaded 338 times
