C5 Corvette cooling fan adjustments?
ObCDN
Post by ObCDN »
I just installed my Intune and cannot find the adjustments for the fans. Are these preset?But advert says it will allow you to adjust these parameters along with some others that I do not see.
Y2K C5
Re: C5 Corvette cooling fan adjustments?
should be under the modify tune menu....
ObCDN
Post by ObCDN »
Went to stock tune and then adjustments,not there.Put in the Diablo tune went to adjustments not there either.Now what?
Y2K C5
what is there?
ObCDN
Post by ObCDN »
ok hers the files
PCM_09357620_LastTuneWritten.grg
(22.11 KiB) Downloaded 193 times
PCM_09357620_Backup.grg
(22.06 KiB) Downloaded 174 times
Y2K C5
after looking over this tune, the settings are lowered by 30* in the 93 tune, load it up and let me know what the temps look like...
ObCDN
Post by ObCDN »
10-4 thanks
Y2K C5
jonkeevy
Post by jonkeevy »
I am having the same issue but I am hesitant about downloading the tunes that are posted earlier in the thread as they may contain other adjustments that I don't want or need.
"I just installed my Intune and cannot find the adjustments for the fans. Are these preset? But advert says it will allow you to adjust these parameters along with some others that I do not see."
I looked and looked but could not find the cooling fan parameters at all. I've installed a 180 degree thermostat and need to adjust the cooling fans.
Any help would be appreciated.
rgav8r
Post by rgav8r »
I would like to have this question answered as well but I am dealing with a 2002 Camaro.
RG
jonkeevy wrote:I am having the same issue but I am hesitant about downloading the tunes that are posted earlier in the thread as they may contain other adjustments that I don't want or need.
you can't use someone elses tune files anyway, won't work for you.. tunes are tied/locked to specific vehicle by VIN number and engine calibration ID's..
the preset tunes have the fans adjusted already as mentioned..
and the stock t-stat is already 187*... so won't really have any benefit/gain going to just a 180 anyway.. fans are already adjusted in the tune and are fine for that application...
