HI
I have checked, And the best solution is to get an Itune that can reset my car to the orignal state as you suggested
From there I will do the step needed to have it properly tuned.
How can we arrange for the Itune solution you suggested to happend ?.
Regards
Tony Marquis
PCM Calibration ID recognition probleme
Re: PCM Calibration ID recognition probleme
just get an intune then let it read the stock tune out and post the backup from the intune and the custom edelbrock tune here.
OK, will do.
You want the Edelbrock •.DRG file not the •.crom file.
One question, wont the Itune tell me that my car is already match win another Tool ?
Regards
Regards
Hi.
Good News! I was able to implemant my Arrington Tune in my car using the Predator deliver origicanly with the Edelbrock Super Charger.
Using the same procedure, it sterted to connect to my car. This must be be an intermitant glitch
I got a InTune ( I-1000 ) , in order to get out of that situation and have more flexibility
Regards
Tony Marquis
Regards
Tony Marquis
good deal.
HI Mike
I was windering 2 thongs :
1 : does the Intune comme with a CD ? ( Their was none in the box ( and it asked many tine for one, so I put a blank CD in )
2 : Is it normal normal to get an error meesage relating to exhaus problem the first time you plug it in your PC ?
Regards Tony Marquis ( get out of the predator )
HI Mikel
After all my problems (See prevuois post), I got this I-1000 and I got an Arrington Tune for it.
I got it in order to get rid on my Predator that came with the supercharger.
But the tool is having problems, even before I try to go install the tune on my car.
I got this on the 15th of June
It froze on the first connection to my PC...but I manage to get it up dated...but
1. Back key does not work
2. The 'Help' key does not work.
3. The key pad is really out of whack! No touch are position ( even with a pen make for touch screen)
4. Every time it get on any PC, it freezes. (The tool)
5. When I connect it to the car (after I go on connected the PC) it blink, and get frozen and teh touch screen get completely white
6. I have to connect it another time on somewhere else to reset it so it connect properly to the car.
All of this has been verify many time in the last 2 evening
Is there a way to fix all these, or should I go to the speed shop and ask them to give me another one?
