2015 F150
Re: 2015 F150
Those are the numbers it gives you when you select the 3.5, but that makes sense, they must be flip flopped.
Re: 2015 F150
I had just updated the tool and loaded the tune the day I posted that. I tried the lower octane time and it does the same thing. I have the truck defined right now as it has to go in for service tomorrow. I'll re address this later in he week.sohfast94 wrote:heath t wrote:Im having part throttle surge issues. Its very bad. WOT feels fine, but between 1/4-1/2 throttle, the truck spits and sputters badly.
Which tune? Please go to options -> show information and get me the verion # off the tool
Also post your last tune written and original backup. If you have any datalogs that is also helpful.
juangorena
Re: 2015 F150
does this update will work with 2015 f150 3.5 Liter ecoboost ?
Re: 2015 F150
Here is the update for the 3.5 fixjuangorena wrote:does this update will work with 2015 f150 3.5 Liter ecoboost ?
- trinity_ford_can_gas-1t13gd_update.crom
- (3.58 MiB) Downloaded 295 times
Re: 2015 F150
Update tool and then program vehicle. Problems are resolved.
- (3.58 MiB) Downloaded 314 times
Insert Clever comment here...
juangorena
Re: 2015 F150
sohfast94 wrote:Update tool and then program vehicle. Problems are resolved.
thank you , tomorrow the truck is going for first service to dealership after that i´ll try it , thank you in advance !!
Omar
Re: 2015 F150
Updated tool just now, reloaded 93 tune, same part throttle surging.
Re: 2015 F150
Post your last tune written please.heath t wrote:Updated tool just now, reloaded 93 tune, same part throttle surging.
Re: 2015 F150
sohfast94 wrote:Post your last tune written please.heath t wrote:Updated tool just now, reloaded 93 tune, same part throttle surging.
- image.jpg (1.45 MiB) Viewed 5176 times
- image.jpg (2.09 MiB) Viewed 5176 times
Re: 2015 F150
hes asking that you connect the trinity to a pc and open dsdownloader and let it connect to the tool, and click the get tune file from tool button and then post the files here.
Re: 2015 F150
mikel wrote:hes asking that you connect the trinity to a pc and open dsdownloader and let it connect to the tool, and click the get tune file from tool button and then post the files here.
Will do this evening. Thanks
Re: 2015 F150
Id rather not attach my file on the open net on here. Can I email it or message it somehow?
Thanks.
Thanks.
Re: 2015 F150
Emailed.heath t wrote:Id rather not attach my file on the open net on here. Can I email it or message it somehow?
Thanks.
juangorena
Re: 2015 F150
i feel very upset, i´m still having issues with the 93 performance tune, after 10-15 minutes i lost all throttle , a check engine lamp pop up , i restore to original back up and lamp still on it feels like a spark plug is failing , i used the tool for diagnostic and it says misfire in cylinder 1 and it still feel very shaky engine with the stock tune ( original file ) at the time to restore it to original tune , the tool frozen with the wait screen 40 minutes
- 240615.LOG
- (489.52 KiB) Downloaded 254 times
- IMG_4870.JPG (89.67 KiB) Viewed 5105 times
- IMG_4869.JPG (95.06 KiB) Viewed 5105 times
- IMG_4871.JPG (91.11 KiB) Viewed 5105 times
- FullSizeRender.jpg (91.21 KiB) Viewed 5105 times
- PCM_PKCMAC7_93_modified.frg
- (15.25 KiB) Downloaded 323 times
Re: 2015 F150
Have you updated to the latest test crom in this thread?juangorena wrote:i feel very upset, i´m still having issues with the 93 performance tune, after 10-15 minutes i lost all throttle , a check engine lamp pop up , i restore to original back up and lamp still on it feels like a spark plug is failing , i used the tool for diagnostic and it says misfire in cylinder 1 and it still feel very shaky engine with the stock tune ( original file ) at the time to restore it to original tune , the tool frozen with the wait screen 40 minutes
