Dodge srv activation in 5.7 challenger gpec2 ecu
Hello quick question, I have heard from a few people on other forums that you can activate the SRV active runner intake in a 5.7 calibration challenger gpec2 ecu using the cmr software, just wanted to verify this is possible. I'd love to ditch my MSD window switch that I am using to activate the runners on my 392 swap and have it as more of an oem setup. Thanks in advance
Re: Dodge srv activation in 5.7 challenger gpec2 ecu
got a calid?
When I get home from work later I'll post it up thanks for the helpmikel wrote:got a calid?
Here is my cal ID 68212719admikel wrote:got a calid?
There is indeed a switch there, I know it works to disable the system on 6.4s, assuming the logic is in place to control it the switch ought to work to enable it as well.
- MTV sol.png (194.95 KiB) Viewed 5163 times
Excellent thank you very much!
