Windows 10 problems
beachking2000
Windows 10 problems
Having issues with dataviewer not connecting to tool in windows 10.
Re: Windows 10 problems
working on a fix.
Here you go.
- DataViewer_3.3.0.16.exe
- (15.32 MiB) Downloaded 2657 times
So should I select to fix C++ or repair still not connecting
make sure the driver is installed?
This software has been tested quite a bit and works fine with win10.
Would this also work on the predator?
Data Viewer still hangs on "Searching for a connected tool" (3.3.0.16)
uninstalled / reinstalled same problem
Win 10 sees the I2 without and problems
Device manager reports the following for the I2
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
uninstall the current drivers through the device manager then load the driver here:
http://installers.diablosport.com/softw ... er_2.5.exe
Already done that three times.
Downloaded the usb 2.5 drivers from your link, but can only test tomorrow, but I see the digital signature date is the same as I have previously used. (22 October 2015)
